tranny problem
Old Jul 26, 2008 | 06:46 PM
99redws6's Avatar
Default tranny problem
Well I've been having problems with my 4l60E in my 99 transam jumping out of gear when at wot. It also has tci 3000 stall. Its fine at 1/2 and 3/4. I've got another tranny and stall on the way but I'm curious to what could be wrong with it. Today I figured out if your doing around 75 or 80 and floor it it will downshift to drive fine and not jump out of gear but if it has to downshift to 2nd i just get a vibration and it hits the rev limiter. Any thoughts on it would be appreciated. Thanks Brandon
Old Jul 26, 2008 | 09:54 PM
FLT's Avatar
FLT
Is this only on the 1-2 shift that it feels like it jumps out of gear? If so I would suspect a band failure.
Old Jul 27, 2008 | 09:28 AM
99redws6's Avatar
It does it before its even ready to shift into second or drive. The only gear it will stay in when at wot is drive. If the band was bad would it cause it to not downshift into second and first when at wot? If it failed are the clutches prolly bad to? Also the fluid has never looked bad or smelled burnt. Thanks Brandon
Old Jul 27, 2008 | 10:51 AM
performabuilt's Avatar
LS1Tech Sponsor
The band could be badly glazed or worn and just not holding at MAX power WOT
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 27, 2008 | 11:55 AM
99redws6's Avatar
Is this something you can fix without having to do a complete rebuild?
Old Jul 27, 2008 | 12:47 PM
LS1Tech Sponsor
Possibly is the rest of trans is good but even so it involves removal and at least partial tear down but with another on the way not sure worth the time and effort,
__________________
Call 888-744-6542
Old Jul 27, 2008 | 12:57 PM
99redws6's Avatar
Yea I dont plan on messing with it. Just curious so if I sell it I can give them an idea whats wrong with it.
