Installed Transgo, now no neutral?!! what gives
Well this will be my 2nd post in regards to my TransGo. I did a search and couldn't find anyone with the same problem. We just finished bolting up the valvebody and everything else, fired the car up, checked fluid everything was good to go.
We ran through the gears (1-2-3-D-R) all worked fine, but when we put it in neutral, the car tires kept going forward.... Put it in park and the wheels stopped.
We called it quits for tonight, but this is such an inconvenience for such a dumb problem. We followed the instructions dead on.
I'm sure performabuilt and Vince will come save my *** yet again!
Question did you try neutral on the ground? In the air the wheels will go forward.
__________________
Thanks again both of you guys, is there seriously anything you don't know??
Can you tell me who the next President is gonna be? haha
If the problem persists, ill be in touch. Thanks!
Noooooooo I left it in the air. Vince just explained that to me. I forgot that there is still some friction in neutral, just not enough to move the car while on the ground.
, AND I COULD TELL YOU WHO IT SHOULD BE BUT HEY IM NOT A DEM OR REPUB BUT A LIB AND THAT DOES NOT MEAN LIBERAL LOL
GOOD LUCK HOPE ALL WORKS OUT
__________________
