2-3 shift not working!!
Old Jul 30, 2008 | 11:40 AM
Rick. Salinas's Avatar
Default 2-3 shift not working!!
ok so i noticed the shifting takes a lil longer. i knew i had to get a tune to get it right for the swap (look at sig) . then lately i would step on the gas in regular drive and the engine would go up to the limiter and wont shift. if i was lighter on it it would shift.. WELLLLLL NOWWW im driving regular and the 1-2 takes a bit and then the 2-3 does not even happen .. i know i need to install my tranny cooler but should i worry about something bigger.. im not savvy on the trannys... also is there any place in Houston i could go thats trustworthy.... thanks
Rick
Old Jul 30, 2008 | 01:21 PM
Gilbert@Ace Racing's Avatar
Based on your description of what took place I would have to say you lost the 3/4 clutches.
What is the fluid condition and fluid level?
We have built many units for guys down in Houston. We are in the Fort Worth area. But, if that's too far to manage.... give Chris at Circle-D a call... also the guys at Century can helps as well. They are both sponsors here.
Good luck.
g
Old Jul 30, 2008 | 03:09 PM
my fluids are good i checked and even added a bit to it to see how it reacted. still the same...that super sucks if its the clutches.. i already contacted circle d so ima head up there one of these days
Old Jul 31, 2008 | 05:37 PM
ford h8tr's Avatar
That sucks, mine is doing the same thing. It is my 3-4 clutches.
