pressure control solenoid?
"I got this code after I fabbed up my new 9 inch rear. I haven't driven it anywhere to get this code. i am also getting a crankshaft position sensor code. I accidentally left the batt cable hooked up while i was welding up the rear
. so..... i am getting another pcm to see if its the problem or of its the sensor. is the pc solenoid hard to replace? what does it do?"Its possible in my mind that there could be a ground or other possible wiring or PCM issue since this and the other code showed up without driving the car right after this mod
