need help asap!
Old Aug 5, 2008 | 07:24 AM
Rickys S/C Z28's Avatar
Default need help asap!
i can get a 4l80 e cheap but its for a 4WD what all do i need to do to put it in a 2000 camaro the 4l80 came out of a 01 chevy pick up ill get the wiring harness that came out of the truck,
thanks for any help
Ricky
Old Aug 5, 2008 | 08:21 AM
FLT's Avatar
FLT
The output shaft will have to be changed. Also due to the fact that you are making this a 2wd, there is a freeze plug in the back of that case. It will need to be removed and a special plug/orifice will need to be installed. This is used to lubricate the extension housing bushing in a 2wd application and of course you will need to get a tail housing.
Old Aug 5, 2008 | 11:14 AM
Bryan @ Speed Inc.'s Avatar
FLT for president!
Old Aug 5, 2008 | 09:42 PM
ok great thanks
