LS1 SFI Approved Flexplates IN STOCK!!
Old Aug 28, 2003 | 03:34 PM
Paul F's Avatar
Default LS1 SFI Approved Flexplates IN STOCK!!
Finally we have some of the TCI flexplates in stock. These are billet steel and SFI 29.1 approved. Here is a link to all of the info. Flexplates
Old Aug 28, 2003 | 04:35 PM
SS00Blue's Avatar
Default Re: LS1 SFI Approved Flexplates IN STOCK!!
$200?!?!?!
Wow, sign me up for two hundred...
SC-
Old Aug 29, 2003 | 08:18 AM
FEAR THE LS1's Avatar
Thats a quality looking flexplate!
I got a quick question about it being light weight. For drag racing should the flexplate be so light? I once installed a light weight flywheel in my 6 speed, the engine rev'd very fast and was great on the streets but when it came to drag racing I lost alot of 60'.
I'm just curious if the lighter flexplate is good or bad for drag racing?
I'm currently running my 2nd stock flexplate. I even have a spare in the garage just incase this one breaks. If the TCS works out I will order one asap =)
Lee
Old Aug 29, 2003 | 09:13 AM
Kevin Winstead's Avatar
Paul, Those are some great looking flexplates!
FeartheLS1,
The flexplate weight is almost an insignificant (as long as it's not crazy heavy) performance factor because of a couple of reasons.
1. Unlike a manual transmission, a torque converter has torque multiplication to help you off the starting line. Torque multiplications of 2.0-2.5 are fairly common. If you take an engine that produces 400 lb ft of torque and multiply it by 2.5...you get 1000 lb ft of torque that is twisting the input shaft of the transmission. A manual transmission doesn't have this additional torque multiplication.
2. A flexplate is generally on the order of 1-2 lbs. It's sandwiched between a 45-50 lb crankshaft that has a 10-12 lb balance on the front of it and a 30 lb torque converter on it's backside.
You wouldn't notice the difference that a few ounces of flexplate weight would make.
Kevin
Old Aug 29, 2003 | 10:49 AM
Gotcha! I will be calling Paul. I am currently looking at different converter manufactures for a new 8" clutchless 5000-5200 stall converter that is LS1 Flex/TH400 tranny compatible.
This flexplate will be going in when I do the new converter =)
Thanks for the info.
Lee
