tranny line fluid flow
Old Aug 7, 2008 | 02:27 AM
cals400ex's Avatar
Default tranny line fluid flow
i just want to make sure i know the exact fluid flow through the tranny lines. i believe it exits the tranny through the lower line on the tranny and then goes to the lower right side of the factory cooler/radiator which then exits through the upper left side of the factory cooler/radiator and then it comes back into the tranny through the upper line on the tranny itself? is this correct? if that isn't a run on sentence then i don't know what is...
Old Aug 7, 2008 | 06:11 AM
FLT's Avatar
FLT
Not sure on the radiator side but the lower fitting on the trans is the pressure out of the trans and the top is the return line into the trans. Vince
Old Aug 7, 2008 | 12:23 PM
cals400ex's Avatar
i would think it would go into the bottom of the radiator first so it will be pumped up while in the radiator, meaning that the fluid is in the radiator for a longer period of time. this would lead to cooler temps. maybe i am wrong but this is my guess...
Old Aug 7, 2008 | 03:13 PM
RENE'S RAGE's Avatar
You are correct output from trans goes to bottom of raditor.
