Need Help Please
Old Aug 9, 2008 | 06:05 PM
PREDATOR-Z's Avatar
Default Need Help Please
I have a FLT stage 5 (vacuum modulated) 4L60E
3800 VIG, with cooler.
I have been experiencing the following:
I get in the car, drive 50 miles, all is well, all gears working fine.
I park, 15 minutes later, I drive again
>this time the tranny is stuck in 3rd gear from go (in OD mode)
>It will manualy shift (back and forth) 1>2>3 no fourth
>I stop again for 5>10 minutes, get back in and all is normal again.
It has been doing this intermitantly, it has 7K miles on it, started doing this past 2K miles, no issues prior.
Could it be solinoid related?
Valve body related?
Vacuum modulated related? (224 117LSA cam plenty vacuum)
Anyone experienced something similar?
BTW, pcm commands are correct.
All help apreciated, thanks
Old Aug 9, 2008 | 08:23 PM
performabuilt's Avatar
LS1Tech Sponsor
I would scan for codes, But also if and or when the PCM was programed for the converter did by chance the tuner delete the test for codes PO751 and PO757 this is always a good idea with a stall and a common reason for intermittent limp mode with a stall and yes some times it shows immediately and sometimes it takes a while then it shows.
But also since it sometimes does it from start up it may be a hard code. Solenoid open/shorted condition/wiring . If you have a scanner as I said scan it first. And make sure your harness connector is plugged in good at the trans.
Hope this helps a little
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 11, 2008 | 06:22 PM
PREDATOR-Z's Avatar
I scanned today and it throws P0757
So what should I do now? replace solinoid (2/3 shift?)
If it is just a tuning issue, how do I do it? step by step please, I'm not an expert at tuning but i manage.
HPT is what I use.
Old Aug 11, 2008 | 07:12 PM
LS1Tech Sponsor
You can of course try changing the solenoid however with a high stall generally thats a code set because the PCM is confused by the Converter, I cant tell you how but I would try deleting the test for the code and you will likely be good to go
__________________
Call 888-744-6542
Old Aug 11, 2008 | 07:26 PM
PREDATOR-Z's Avatar
I've read about 20 threads, all say the same thing as you do "turn it off"
But HOW? is my question I have HPT.
Where do I go and clic on what?
Thanks for helping me identify the issue.
Old Aug 11, 2008 | 07:27 PM
LS1Tech Sponsor
I would post that question in the tuning section
__________________
Call 888-744-6542
Old Aug 11, 2008 | 07:35 PM
PREDATOR-Z's Avatar
Just did that, I hope i get help. As good as I am with harware, software tech kicks my ***, but I'm willing to learn
Old Aug 11, 2008 | 07:43 PM
LS1Tech Sponsor
Cool and good luck I myself am trying to learn my way around EFI LIVE
__________________
Call 888-744-6542
Old Aug 12, 2008 | 03:13 AM
PREDATOR-Z's Avatar
Ok I got it this is how it is done with HPT:
>Go to VCM Editor
>Open you Bin file
>Go to Eng. Diagnostics
>Go to DTCs
>Scroll to p0757
>leave enable box blank
>Next to that box you'll see 1 of these 4 settings
0-MIL on first error
1-MIL on second error
2-No MIL light
3-No error reported
> click on # 3 (no error reported)
>Flash PCM
There you go,
I hope this helps others, I've seen a lot of posts but no one posted a way to do it with HPT.
Thanks again to Perfomabuilt (it is Frank?) and Dmoney who answered in Tuning section and also Vince (FLT).
I hope this takes care of this annoying limp mode issue.
Mark
Old Aug 12, 2008 | 07:32 AM
TXZ28LS1's Avatar
hey predator-z, i was having the same issue after i got my cam and stall done. i was driving home and it just started bucking and dying out all over the place and threw the same code. P0757 shift solenoid stuck on. i sent my pcm back to MTI and they just deleted that code along with P0751. its been good to go since.
Old Aug 12, 2008 | 09:30 AM
LS1Tech Sponsor
>Go to VCM Editor
>Open you Bin file
>Go to DTCs
>Scroll to p0757
2-No MIL light
3-No error reported
>Flash PCM
There you go,
Mark
Your welcome and Yes its Frank at PerformaBuilt and hopefully your all fixed now
__________________
Call 888-744-6542
