Anyone have torque specs?
Old Aug 9, 2008 | 09:13 PM
9000th01ss's Avatar
Default Anyone have torque specs?
Bellhousing to case
Extension housing to case
Bellhousing to engine
Torque converter to flexplate.
I have the rest.
Thanks.
Old Aug 10, 2008 | 05:24 AM
FLT's Avatar
FLT
Originally Posted by 9000th01ss
Bellhousing to case 55ftlbs
Extension housing to case 32ftlbs
Bellhousing to engine 35ftlbs
Torque converter to flexplate. 46ftlbs
I have the rest.
Thanks.
I did a quick search and this is what I came up with below from http://www.texasfbody.org/TorqueSpecs/#4L60E
Accumulator Cover to Case Bolt 6-10 lb ft
Case Extension to Case Bolt 31-35 lb ft
Case Extension to Case Bolt (4WD Shipping) 8.3-16.7 lb ft
Converter Cover Bolt 89 lb in
Converter Housing to Case Screw 48-55 lb ft
Cooler Pipe Connector 26-30 lb ft
Detent Spring to Valve Body Bolt 15-20 lb ft
Floor shift Control Bolt 89 lb in
Flywheel to Torque Converter Bolt 46 lb ft
Forward Accumulator Cover to Valve Body Bolt 6-10 lb ft
Heat Shield to Transmission Bolt 13 lb ft
Line Pressure Plug 6-10 lb ft
Manual Shaft to Inside Detent Lever Nut 20-25 lb ft
Negative Battery Cable Bolt 11 lb ft
Oil Level Indicator Bolt 35 lb ft
Oil Pan to Transmission Case Bolt 97 lb in
Oil Passage Cover to Case Bolt 6-10 lb ft
Park Brake Bracket to Case Bolt 20-25 lb ft
Park/Neutral Position Switch Screw 27 lb in
Plate to Case Bolt (Shipping) 20-25 lb ft
Plate to Converter Bolt (Shipping) 20-25 lb ft
Plug Assembly, Automatic Transmission Oil Pan (C/K) 22.1-29.5 lb ft
Plug Assembly, Automatic Transmission Oil Pan (Y) 20.7-23.6 lb ft
Pressure Control Solenoid Bracket to Valve Body Bolt 6-10 lb ft
Pump Assembly to Case Bolt 19-24 lb ft
Pump Cover to Pump Body Bolt 15-20 lb ft
Shift Cable Grommet Screw 15 lb in
Shift Control Cable Attachment 15 lb ft
Speed Sensor Retainer Bolt 7.7-10 lb ft
Stud, Automatic Transmission Case Extension (Y-car) 13-16 lb ft
TCC Solenoid Assembly to Case Bolt 6-10 lb ft
Trans Mount to Transmission Bolt 18 lb ft
Transmission Fluid Pressure Manual Valve Position Switch to Valve Body Bolt 6-10 lb ft
Transmission Oil Cooler Pipe Fitting 26-30 lb ft
Transmission Oil Pan to Case Bolt 7-10 lb ft
Transmission to Engine Bolt 35 lb ft
Valve Body to Case Bolt 6-10 lb ft
Old Aug 10, 2008 | 07:55 AM
9000th01ss's Avatar
Ah, I searched here and came up with a million torque converter posts.
Thanks.
Old Aug 10, 2008 | 08:29 AM
FLT's Avatar
FLT
I google everything these days. The info is out there for what ever you are looking for. Just takes some time to find. I just got done doing a search for a recipe for pork tenderloin. Time to head to the store! Good luck with your project. Vince
