4l60e tech questions?
Old Aug 18, 2008 | 12:18 AM
MYCHEVYIIFAST4U's Avatar
Default 4l60e tech questions?
Have a 64 chevy nova wagon and a 63 2 dr hardtop. I am planning on installing a LS1 into the wagon first to build a nasty sleeper with a 4l60e so that I can leave the bench seat. I will leave the 6 speed for my 2dr. Anyways how expensive is it to build a 4l60e to handle heads, cam and possibly ls6 intake? Another trannys that would be easier to build that still have overdrive? THANKS
Old Aug 18, 2008 | 12:27 AM
performabuilt's Avatar
LS1Tech Sponsor
i would suggest you just buy a trans 4l60e from us or any sponsor here as a better idea
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 18, 2008 | 12:43 AM
Yea I am not sure yet but I will keep you in mind.
Old Aug 18, 2008 | 12:57 AM
LS1Tech Sponsor
Not trying to sell you anything just and FYI wether its us or another sponsor there is more to making these trans live than parts trust me and we have all worked hard to make it happen
__________________
Call 888-744-6542
Old Aug 18, 2008 | 05:33 AM
FLT's Avatar
FLT
Well a built 60 should work for you. What will be the weight of the car and also the rwhp/rwtq be? These are a few thing to look at when choosing the correct trans for your application. Feel free to give us a call. Vince
Old Aug 18, 2008 | 05:27 PM
Not sure exactly on the weight of the car. The curb weight from the factory was around 2950-3000lbs. However the tci front suspension clip that I have installed is suposed to drop 150 lbs off of the front end. THe other factor is that the original curb weight was with a powerglide and a straight six. So I am guessing it should be between 2900 and 3000 just becuase of how light these aluminum block ls1's are compared to a straight six or even a cast iron v-8.
As far as hp....I am shooting to have the car at least in the twelves if not high elevens. Dont want anything faster then 11.49 or I will have to have a cage. Not sure what kinda hp that means though. I am guessing 400 at the wheels?
Old Aug 19, 2008 | 12:00 AM
FLT's Avatar
FLT
I think one of our level 3 or 4 units will work just fine for you. Give us a call to discuss your options or even shoot me a pm. Vince
