took a ride on the roll-back...
Old Aug 24, 2008 | 07:25 PM
Superado's Avatar
11 Second Truck Club
Default took a ride on the roll-back...
leaving work yesterday...jumped into an opening in traffic in front of the store...
prolly half throttle...stumbles...loud noise
revs high...nothing...pull over into driveway next door (how ironic...a funeral home)...
no 1, 2, 3, D or R...nothing
I'm sitting in an uphill driveway so I put it in P...it holds so I'm thinking...well, it's not the diff...or the output shaft, right?
to double check I put it in D w/ the PB on and look underneath @ the DS...not spinning...
thinking pump now...
called the hook and took the roll-back ride of shame to the house...
frustrated enough to not mess with it last night not a happy camper!
this morning I check the trans fluid cold...motor not running...crank it up and re-check fluid level...way lower...pump's working
converter? input shaft?
Old Aug 24, 2008 | 07:52 PM
performabuilt's Avatar
LS1Tech Sponsor
Input shaft or drum would be the likley cantidate
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 24, 2008 | 10:32 PM
Superado's Avatar
either usually take out anything else with it?
Old Aug 24, 2008 | 10:35 PM
03 snake's Avatar
Sorry that happened man I hate that feeling.. Vote for drum here.
Old Aug 25, 2008 | 11:06 AM
FL_BILL's Avatar
A similar event happened to me about 2 weeks ago. It was the pump.
Old Sep 9, 2008 | 01:35 PM
Superado's Avatar
well...
here is the list I just received:
Forward Drum – 4L65e Type
Banner Kit
Steel Kit
Wide Band
Molded Piston Kit
Pump Bushing
Case Bushing
1-2 Accumulator
2-3 Accumulator
Deep Pan Filter Kit w/ Pan Gasket
