Would I need tuning with a TCI 3500
No.
I did raise the converter lockup points but that's just a personal preference. I like my converter to only lockup in OD and only above 50 MPH. By no means is doing this necessary though.
It'll need to be a really good hooking track (biggest factor.) The tires will need to be in good shape. And you'll need to do an great burnout with the tires at about 20-23 psi hot.
It won't be easy. I can hook the TCI 3500 with my 315 Nittos but obviously they have alot more rubber on the ground than yours.
