4L60E stays in 2nd gear
Old Sep 3, 2008 | 05:20 PM
svaras's Avatar
Default 4L60E stays in 2nd gear
I need your help guys..
I just finished a swap of a LQ4/4L60E onto my Jeep Wagoneer.
Everything looks ok with the engine but I´m having troubles with the 4L60E.
If I shift into D it goes 1st then 2nd and stays there……
If I do it manually, I can shift 1st, 2nd and when I shift 3rd it goes as neutral…no power at all.
The wiring harness is from the donor truck, a 2002 Chevy 2500 with the LQ4 and a 4L80E.
Nelson Performance custumize the harness and reprog the ECM. They did repin the plug of the harness in order to work with the 4L60E.
Any clue on this ¿?
Looking forward for your help
Thanks
Sebastian
Old Sep 3, 2008 | 05:32 PM
performabuilt's Avatar
LS1Tech Sponsor
Scan for codes first thing
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
