4l60e to 700r4
Old Sep 4, 2008 | 04:46 PM
z28matt's Avatar
Exclamation 4l60e to 700r4
I'm recently just blew my 4l60e, and I found a 700r4. So does it just bolt right in? Or what all do I have to do to get it to work?
Old Sep 4, 2008 | 05:13 PM
performabuilt's Avatar
LS1Tech Sponsor
You would need a way to control lockup and you would need a 93 throttle body to hook the tv cable, You would be better off getting the correct trans for your car
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 4, 2008 | 08:52 PM
95 droptopz's Avatar
got a 700r in my 95. you could fab up a bracket for the tv cable or do like me full manual valve body, as far as lock up you can buy a switch that you control yourself easy to hook up, you also need the tail shaft off your 4l60e. Other than that its a straight swap not hard it does away with the electrical on the trans. \so if the price is to good to pass up it can be done but other wise I would stick with what perform said (4l60e). I did my swap cause my trans was tost and already had a 700r4 built from another car waiting for a home.
Old Sep 4, 2008 | 09:02 PM
z28matt's Avatar
i found one for cheap, but i think I'm just going to get another 4l60e from the same guy. Just to be sure theirs no difference between the 94's and 97's 4l60e right?
Old Sep 4, 2008 | 09:14 PM
LS1Tech Sponsor
Yes unfortunatley you can only use a 94 without modification for the PWM lockup used in the 95 up units
__________________
Call 888-744-6542
