Will this be the same?
Old Sep 5, 2008 | 04:35 PM
jcews6's Avatar
Default Will this be the same?
Will a 700r out of a 1989 chevy pickup with a 4.3 work in my 1993 trans am? or is something going to be different?
Old Sep 5, 2008 | 05:00 PM
performabuilt's Avatar
LS1Tech Sponsor
Its can be done but you will have to make a couple changes to allow for lockup little wiring changes
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 6, 2008 | 12:47 AM
silvermullet's Avatar
Don't use it, it's meant for a 6 cylinder with 160 hp, different calibrations, fewer clutches, smaller servo, smaller boost valve etc. You could change all this out but you might as well go through your original trans. Good luck!
