Remove tranny without removing exhaust?
Old Sep 6, 2008 | 04:38 PM
john shea's Avatar
Default Remove tranny without removing exhaust?
Is it possible to remove the transmission without removing exhaust?
Old Sep 6, 2008 | 05:03 PM
omcar's Avatar
i just removed the tranny and had to drop the exhaust..
Old Sep 6, 2008 | 05:56 PM
Badazz 97 TA's Avatar
if you have longtubes you dont have to. if you have stock exhaust most likely you will have to drop it.
Old Sep 6, 2008 | 06:12 PM
Breaking Stuff's Avatar
You wont have to with stock exhaust either.
Old Sep 6, 2008 | 10:16 PM
twizted_creations's Avatar
Depends on the year, and another thing I was thinking is the car we just worked on was a "repair job" by an exhaust shop. It had a small flex pipe and the passenger cat was further back... 99 if that helps. Not like the ones right off the manifold. But we did pull a trans outta a 99 without touching the Y. Only reason we didnt put the Y's I have on it is it wasnt gonna fit.
