Tranny is not engaging...
We dropped the old tranny and put the stall on the new one, seated it properly, and spun it to check to see that fluid came out of the tranny, it did.
We then hoisted the tranny and stall up and bolted everything together. We did not shim the stall, but neither did the previous owner. Before we let the car down, we started the car to see if fluid came out of the lines, it did again, so we buttoned it all up.
The car ran great for a while, ran a 7.7 at Irwindale (1/8 mile) with a 1.6 60'. Less than a few hundred miles later while exiting the freeway his tranny seems to have gone out. Every gear is like neutral, you give it gas and nothing happens. Disconnected the lines from the tranny and started it and no fluid flows now, I am dumbfounded.
Where can I buy a kit to replace the pump? How much is it? How difficult of a job is it? Are there any write-ups/pictures of the pump R&R? Sorry for all the questions. Thanks for the help. I really appreciate it.
Thanks!!
