vig 3600 with new cam
Old Sep 6, 2003 | 09:34 AM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Default vig 3600 with new cam
I have a vig 3600 multi disc with a g5x2 cam i know this cam needs more stall.At the track with new cam and et streets best 60ft was a 1.68.I ataped the car on it's runs to see were it's flashing but i can't tell were it is .What do i look for i know if i send it out they want this info.Or am i better off getting a diffrent converter i here some negs on vigs.I don't want to spend the money on a diffrent converter if i don't have to. payed alot for this being a mlti disc. need some opinons thanks
Old Sep 6, 2003 | 10:10 AM
Z-Rated's Avatar
Default Re: vig 3600 with new cam
What tire pressure were you running? I think the streets work well really low like 13-16 psi. Did you try changing how you launch? Like stepping up 500 rpm till you see better results? And do you have any suspension upgrageds?
Old Sep 6, 2003 | 08:45 PM
tuff's Avatar
I'm running 15psi and i have spohn tork arm and lowers i've tryed lowering psi all the way to 10psi in steps. I just want to know if this converter is worth getting it tuned and how to tell were it flashes. when i tested my car the track was not the best and it was hot. But with a cam like i have i think i need a bigger stall.
Old Sep 6, 2003 | 10:30 PM
CamaroCain's Avatar
take the car to Speed Inc and get it tuned, it needs it bad, my car with just bolt-ons made a world of difference with tuning. I used to run a Vig3600 and did very well with it running a best of 11.7 with mid 1.5 60' with very few mods. If you do decide to go with another converter though I highly recommend TCS. They are a sponsor on here and as you can see from my sig their converters perform just was well as the more expensive Yank TP series. You could always take the car back to Speed Inc for some adjustments when/if you change converters.
Old Sep 7, 2003 | 10:46 PM
Got Me SOM's Avatar
from my research done, you're gonna need a bigger stall. wow you live right by me, i'd like to come check out your ride before I head back to FLA.
Old Sep 8, 2003 | 09:05 PM
tuff's Avatar
Sounds cool we can hook up i'm planing on going to the track sat byron of course no cage. I'll be getting my innovate wideband system so i'm going to be messing around with that during the week. I live right around the corner from speedway gas station on swift and north ave. let me know.
Old Sep 9, 2003 | 04:20 PM
98TAauto's Avatar
i know the sift extension on that cam goes back to 5400 on mine.... i think you will be happy with that stall
i have the vig3600 and just the 224/224 and ran 11.50
Old Sep 9, 2003 | 06:19 PM
tuff's Avatar
I don't want to sound retarded but what do you mean by sift ext. I asked this once before and no reply.By the way are cars weigh the same i would love to see some low 1.5 but i don't think it's possible and i do run et streets.
 Michael S. Palmer
Old Sep 9, 2003 | 08:54 PM
CamaroCain's Avatar
How much did you pay for that? Not trying to be rude, just speaking from experience here. You would probably be much better off letting a professional tune your car instead of spending the same amount or more on stuff to try to do it yourself and not know how it works or what to do. JMO
Old Sep 9, 2003 | 09:18 PM
tuff's Avatar
Your probley right and i will still end up geting it tuned by a pro but i figure if i run the bottle next year i'll be able to keep a eye on my afr. And most people would say spend the money now to get it tuned but with work being so bussy it's hard to get away.Night time is my only play time.
Old Sep 9, 2003 | 09:31 PM
98TAauto's Avatar
shift extension: is how far the rpms drop back down to after a shift. The bigger the stall, the less rpms they drop. You want a stall thats gonna keep you in your power band the best. Normally a 4400 stall drops back to 5600 rpms I think, maybe more. My 3600 drops back to 5300-5400.
when i flash the stall, on atap it usually jumps to 4000rpms, so a vig3600v is really a 4000stall like everyone says.
the norm 60ft for a bolt on vig3600 car is 1.6's
Ive been 1.58 stock internally on nittos with it(3.23s), and Lynda's been 1.5's. With just the cam, ive been 1.55's on et streets. With the heads I hope to pull 1.50's or better if my gear and rear lets me.
you should have no issue pullin 1.5's with heads/cam and that stall! The only weight mods I have are the seats out... sway bar has never been off the car and i run stock shocks. Raceweight from 3450-3550 usually
good luck, and I think you would be happy with this stall..
one other I would reccomend is the TCS 4000-4200 stall(anything in the 3600-4200 range is perfect)
Old Sep 9, 2003 | 09:47 PM
tuff's Avatar
Thanks for the info i'm going to look at my last atap run. My car has alot of good componets to get the job done we will see after i tune it if that don't work i'm going to have to find time to get it done. I'm hopen this weekend to get to the track if the weather is good.afr is way off hope to get it close with innovate wideband system before the weekend.
