3-4 Clutches Keep Burning up...........????
Now, the first time we replaced them....we didn't disassemble the tranny totally and clean. We jsut replaced and cleaned what we came in contact with for the 3-4 clutch replacement. This time.....we have it totally apart and have found NOTHING that woudl show signs of why this has happened again...other than alot of clutch material in the tranny. Valve body had alot as did most of the tranny. Now all is cleaned...and nothing hard part wise is showing a reason for the burned up clutches. Only other suspect left is the pump.
My tranny guy feels like the solenoids are good since i had the dealer check it before the tranny was removed...and there were no codes and the car would drive all day long 1-2 gear....just nothign after that due to burned up clutches. My Vig 3200 was sent out to be inspected.....all is good there also.
I don't know if i should just assume the clutch material contaminated it to much...of maybe just the pump is messing up and not giving enough line pressure....either way.....i am stumped as is my tranny guy.
Any ideas on what could cause this??????
