Tranny cooler ?
Old Sep 22, 2008 | 01:22 PM
jlam411's Avatar
Default Tranny cooler ?
I am about to install a new tranny cooler on my car after the first one was installed seemingly wrong by whoever did it. Ok do i run the lines through the radiator and then the tranny cooler, or is there a better way. If so which line are the feed and return lines.
Old Sep 22, 2008 | 01:28 PM
frito1's Avatar
The bottom line to the radiator is the pressure and the top is the return. Route the cooler inline from the return fitting of the radiator cooler. It will cool the ATF even further than the radiator does.
Old Sep 22, 2008 | 01:37 PM
koolaid_kid's Avatar
I suggest bypassing the radiator completely. It will "cool" the fluid to the water temperature, which is generally 200 degrees or more. My trans temps run around the 160-180 range. Cooler is better.
Old Sep 22, 2008 | 03:41 PM
frito1's Avatar
The reason I didn't bypass my radiator is in the winter months, the radiator actually acts as a heater to the trans helping warm it up quicker to operating temps. It just acts as a good "regulator" with the cooling system's thermostat to warm up the trans quicker. JMO
Old Sep 22, 2008 | 05:50 PM
Blk_Ws6's Avatar
Not having a cooler and racing alot will that hurt your a4?
Old Sep 22, 2008 | 07:34 PM
I agree it acts as a heater, which was also my point in bypassing it. Since I live in Indiana, I let the car warm up in the -20 degree weather before driving it. And it still runs nice and cool in all weather. JMHO.
Old Sep 22, 2008 | 07:36 PM
Yes. A cooler will help it live longer, even a stock one. Cheap insurance, IMO.
Old Sep 22, 2008 | 07:46 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Unless you live in a cool climate state, I would by pass the crappy radiator cooler.
Old Sep 22, 2008 | 09:16 PM
Blk_Ws6's Avatar
Thanx fellas.
Old Sep 22, 2008 | 09:17 PM
Blk_Ws6's Avatar
this is gonna be my 4th rebuild.
Old Sep 22, 2008 | 09:34 PM
frito1's Avatar
Wow!
Old Sep 22, 2008 | 09:45 PM
frito1's Avatar
Well, I think you know what I meant... acts as a heater in the winter, and it cools the in summertime. Don't kid yourself, the radiator is cooling some initially before it hits the B&M 24K. I searched this before doing mine and it seemed that most were retaining the stock cooler so it knocks down some of the heat before seeing the external cooler. It is really up to the individual. I saw it as an asset so I left it...
Old Sep 24, 2008 | 12:50 PM
LS1nut377's Avatar
bypass the radiator and run the cooler.
Old Sep 24, 2008 | 04:27 PM
Yes, I understand what you meant. I don't agree, but that does not mean that either of us is wrong. It merely means that our opinion differs.
Old Sep 24, 2008 | 05:09 PM
BubaGumpShrimp's Avatar
you will get the best cooling if you have the fluid run through the radiator then threw the cooler unless you got a huge cooler. The radiator will suck out 15* or more before it gets to the cooler which will then take more heat out. I usually run in the 140-160 range this way, summer included.
Old Sep 25, 2008 | 03:16 PM
jmoo86's Avatar
I ran mine solo. I prbly burned up 4 transmissons before the cooler. The last one has lasted well over a year.
Old Sep 25, 2008 | 06:48 PM
Blk_Ws6's Avatar
so without the cooler thats why you was burning out your trannys?
Old Sep 25, 2008 | 06:49 PM
Blk_Ws6's Avatar
Because I'm on my 4th rebuild to.
Old Sep 28, 2008 | 06:02 PM
WYATT318MOPAR's Avatar
I bypassed the radiator got a two row 26 inch long derail I believe trans operating temp is like 153* that is after driving it hard and launching several times...Just setting it will stat at around 129* I checked it several times with a infared temp gun...
Old Sep 28, 2008 | 06:07 PM
tording99Z28's Avatar
I too say bypass the radiator. The radiator does help bring the temps up to operating temperature but for it to be an issue it would have to be probably -20 degrees all winter long. Just bypass the radiator and run the cooler.
