strange shift extension
Old Oct 5, 2008 | 04:07 AM
1dirtyZ's Avatar
Default strange shift extension
took the stang out a few days back for some testing of the new combo, the strange thing that happened is when shifting from 1st to 2nd and 2nd to 3rd rpms drop from 6200 to about 4200-4300 rpm's . i know that sounds lke a lot of drop , but why is it doing so? could it be driving through the converter?
the car is a 92 mustang with 408 and an f2 blower , yank 4000 stall ( built for this engine,trans,gearing combo but on a slightly heavier car), th-400 , 3.55 gears, 28 inch slicks.
any thing i should check , or should i look into a new converter?
Old Oct 5, 2008 | 11:45 AM
performabuilt's Avatar
LS1Tech Sponsor
If the converter was intended for a heavier car the characteristics of the converter will be different in the lighter car
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 5, 2008 | 04:12 PM
1dirtyZ's Avatar
but would it cause the symptoms i'm having?
Old Oct 5, 2008 | 06:32 PM
LS1Tech Sponsor
Well lower weight changes the stall characteristics so yes it could very well affect "shift extention " I would think
__________________
Call 888-744-6542
Old Oct 6, 2008 | 10:24 AM
Yank's Avatar
Give us a call at 775 826 9955 we can give you some other areas to look into
