2-3 shift problem
Old Oct 6, 2008 | 08:56 PM
hitemup9nine's Avatar
Default 2-3 shift problem
I have a problem with my car not shifting to third gear under full throttle. When doing normal driving the car shifts fine. First-Second shift shifts good. Just getting into third gear it over revs. Tranny was just built about 15k miles ago at most. No codes popping up.
Old Oct 6, 2008 | 09:02 PM
Blownz28man's Avatar
I'm having the same problem! Can't figure it out. Messed with the tuning, asked for a lot of help by some tunning experts.. Next is to hook up a pressure gauge.. It has a stall 3500rpm and shift kit. I'll keep you posted with diag. good luck.
Old Oct 13, 2008 | 05:36 PM
So after a little reading on here I'm thinking it could be my 3-4 clutches going out or I read somewhere where the tunning on shift points might be the problem. Where the shift command might need to be lowered to the actual shift point. I figured if my 3-4 clutches were going out wouldn't my tranny be slipping. Any suggestions?
Old Oct 13, 2008 | 06:08 PM
the_merv's Avatar
It's the Tuning, set the MPH for the 2-3 Shift a little lower, that will more than likely take care of it.
Old Oct 13, 2008 | 07:01 PM
thanks for the help hopefully this works.
