TH400....short or long tail and why?
Old Oct 9, 2008 | 11:03 AM
White.Lightning's Avatar
Default TH400....short or long tail and why?
Hey guys. Ive searched with no real answers. TH400 short or long tail and why???
Thanks
Andy
Old Oct 9, 2008 | 11:37 AM
TurboAv's Avatar
I believe the short tail has a bigger output shaft, so higher power limits???
Old Oct 9, 2008 | 10:02 PM
smok'nZ's Avatar
MASS seller approved
short tail needs a custom ds a long tail i thinks its 9" can use stock length one
Old Oct 10, 2008 | 05:21 AM
Ok cool. I think there is a 4", 9" and 12" tail. I was more concerned that the short tail wouldn't line up with the trans crossmember. I'd be getting a driveshaft either way so using the stock driveshaft isn't a concern.
Old Oct 11, 2008 | 12:38 PM
smok'nZ's Avatar
mine has a 6" not 4 or 9 where are you buying one from?
Old Oct 11, 2008 | 12:41 PM
pddye's Avatar
I think mine had a 4" not a 6". It also uses a bigger output shaft. Had a driveshaft made up from strange and got it from Erik at midwest chasis. He has a heck of a deal on chromemoly driveshafts. You'll also use the same mount a a 6 speed t56.
