question on programmers and engine covers
Thanks for the help
The Predator tune will add 15-20 rwhp to your CTS-V, while also reducing the torque management, disabling the CAGS skip shift function, and increasing the throttle response. I can assure you that short of a used N20 kit, there is no better bang for the buck, especially on a car with limited mod plans (but we all know how that works out...
).The Predator also allows you to read and clear trouble codes, and datalog the car, plus it has several adjustable parameters to allow you to dial in the tune or modify it to your liking.
You can change rev and speed limits, alter timing or fuel at WOT, adjust for different gears or wheels /tires, and more.
Oh, and it supports custom tuning for when you do eventually go mod crazy....
As far as frc's they do fit. Slightly dremel trimming is needed, but its very mild and easy to do. They run about 75-125.00 depending on demand and condition
DYNO TUNE dumdumdum.
I got tuned by one of the ppl responsible for building the stock tunes for the diablosport programmers....so Im not being biased.....just honest.
Car runs 100x better with the dyno tune than it did with the can tune
