Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
odd problem
Old May 6, 2011 | 05:32 PM
EHam's Avatar
Default odd problem
when i turn on the windshield wipers it starts spraying washer fluid. does it when i pull the handle down also. any ideas on how to fix this without taking it to the stealership?
Old May 6, 2011 | 07:58 PM
JJSimon904's Avatar
Never seen that before..wow. Maybe something is shorted in the column so when the wipers come on, the washer fluid comes on too.
Old May 6, 2011 | 09:56 PM
06blackonblackctsv's Avatar
Mine has been doing the same thing for a couple months now, I ran all the fluid out, but I can hear the motor start spraying every time I use my wipers. I try not to drive the V when it rains, but I still need to get it fixed.
raven154's Avatar
I think I remember someone having this issue and it was the relay. Not 100% sure on that though.
Old May 6, 2011 | 10:37 PM
JJSimon904's Avatar
Makes sense if it is powered by the same power source as the wipers.
Old May 7, 2011 | 02:05 PM
EHam's Avatar
I am sure it will be expensive as is everything else for this car.
Old May 24, 2011 | 08:33 AM
JD03Cobra's Avatar
I am having the exact same problem with mine. It started spraying just a little at first when I turned on the wipers and now it continuously sprays.
Anybody figure out a fix yet?
Old May 31, 2011 | 12:48 AM
No fixes yet? I really dont wanna take it to the dealer. I guess I will just keep my music up so I cant hear the motor whining when it rains.
Old May 31, 2011 | 06:28 AM
Skidmarcx's Avatar
Sounds like it could be a bad switch... unless there's a control module for the wiper system that could be the problem
Old May 31, 2011 | 06:53 AM
STAGEUP's Avatar
Unclip the power connector to the washer motor. Problem solved.
Old May 31, 2011 | 06:54 AM
Skidmarcx's Avatar
^^ LOL... and a little RainX
Old May 31, 2011 | 07:38 AM
detaillls's Avatar
Or pull the fuse if it's an isolated fuse... doesn't seem like it would be on the same one as the wipers due to amp size needed.
Old Mar 9, 2013 | 03:16 PM
81LS1Camaro's Avatar
Did you guys ever fix yours? I bought a V a week ago and apparently my washers are always on with the wipers too.
Old Mar 27, 2013 | 01:43 PM
Well I decided to throw a switch at it with no luck. Anything common I should check?
Old Mar 29, 2013 | 01:28 PM
EHam's Avatar
haha, i posted this almost 2 years ago and still havent fixed it. Whats really annoying is when the wipers stop right in the middle of the windshield. I have to keep hitting the button till they stop in the right place or i turn the car off. Pretty slack on my part but i guess it doesnt bother me enough to fix.
Old Mar 29, 2013 | 03:30 PM
slowlaneblues06's Avatar
Malfunctions like this in moist any car are ususally the multi function switch. It is possibly a relay, but it would not be a fuse.
Old Aug 3, 2013 | 08:41 PM
DVS 99's Avatar
Has anyone found the solution for this. My wipers work like they should but if you just push the button for the washer it will spray, wipers come on but won't go off until you turn off key.
Old Aug 3, 2013 | 08:52 PM
DougNuts's Avatar
I think this issue is the wiper motoron these cars. It's not sealed up good enough to protect from the elements.
Old Aug 4, 2013 | 02:12 PM
rbsurfer's Avatar
If its the motor how will it spray continuously when there on I have same problem but my wiper switch stick feels loose kinda
Old Aug 5, 2013 | 09:47 PM
D Block's Avatar
Wiper control module which is connected to the wiper motor. Someone said you can just buy the cover (where the module is located) seperately from the motor assembly. I bought the motor assembly from rockauto. Problem solved. Easy to change also.
