Check Engine Light
I installed some long tubes, high flow cats, and a catback. My check engine light came on afterwards. I forget the code #, but it was "catalyst efficiency below threshhold" for both banks.. just wondering if a tune will knock those codes out?
Also, my oil pressure is reading 130 psi with the car on or off.. so i know its not running that high. has anyone had this problem? Does the sensor need to be replaced?
Thanks
Thanks
I was fighting the cat eff and evap since august of 11.
It was a real nightmare and I spent over $1k in gas and chasing ghosts (like replacing sensors and blown out header gaskets) driving all over creation trying to get the tests to either run and at least one of them.
I haven't had a chance to run the car yet, but I have been reassured my smog test problems are fixed.
As it is, I am good for this year and next year is my "by" year so I don't get machine tested till 1214.
I will be ready for them this time!
