160 stat
Jersey
Jersey
If you are running 192 with a 170 stat, what the heck was it running with a stock (192°) stat? I have stock cars that run 192 on the freeway. Do you have your fan temps lowered to match your stat? As LS1LT1 said, you must have the fan temps changed to take advantage of the lower stat.
But to get back to the question, yest it will make a difference if you get the stat and the fan temps changed. Your car will run cooler, and be less prone to detonation. Not such a big issue on a stock car (although the V seems prone to detonation in stock form when it gets hot) but it becomes more helpful when you start adding more power, epsecially forced induction.
Jersey
