Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
My V finally Feels like a " SPORTS " sedan
Old 11-07-2009, 09:00 PM
maxspeed96ct's Avatar
Default My V finally Feels like a " SPORTS " sedan
I just installed :
- stage 3+spec clutch kit with steel fly and the spec slave
- Creative steel motor mounts
- UUC Diff bushing
- Filled the stock trans mount with 80a urathane
My car feels solid. Feels like a totaly diffrent car, between shifts you can just feel the power .. I love it..
The down side is there is slightly more small drivetrain noises/vibration but no more major clunk ..
The clutch
- feels good, Grabby but pedal feels good. It has no chatter but does have a slight bounce/jerk if you let the pedal off to fast. and no more second gear starts...I used the spec salve that was 200$. I tried to first use a F-body slave but the fitings were totaly diffrent. The Spec slave is identical to stock, even has the same part number stamps . The only down side is the Tick bleeder Did not fit. Total for clutch and slave was $950 and the $80 harbor fright jack made it a one man job (but it wasnt easy)
The motor mounts
-Look good, my stock ones were shot. I even have a video of how bad they were. No more rattle during shutdown so im happy. I also wrapped them with exhaust wrap because they are very close to the headers. It will prevent the polly from melting... The downside was I had to remove the Kooks to get them off. Inspector gadget would not be able to get to the bolts on the mounts...
The Diff bushing
-Looks much better then stock, my stock one was shot.
The trans mount , used the 50$ can of 80a urathane (the might mouse way)
The stock one is very soft and flimsy
Cant wait till the spec breaks in so I can realy open the Ls6 up
Now pics and i have a video of the stock fly and motor mount.
Enjoy and feel free to ask questions.
The clutch
Fbody slave next to the cts-v slave
Mounts
Mount before wrapped it.
Old 11-07-2009, 09:03 PM
stock Motor mount
http://www.youtube.com/watch?v=OdHv5RGakgo
Stock flywheel
http://www.youtube.com/watch?v=zF5JeNENMUU
Old 11-07-2009, 09:07 PM
jonyb's Avatar
Wow..... Nice work.
Old 11-07-2009, 09:46 PM
jerrad's Avatar
Great idea on the header wrapped mount.
Old 11-08-2009, 09:04 AM
lubelizard's Avatar
Info on the source of the urethane? Thanks.
Headers in or out for engine mounts?
Old 11-08-2009, 09:10 AM
SoJersey05V's Avatar
yea i should have wrapped my uuc mms with that!!! i gotta get a diff bushing too... who has the puller now-a-days?
Old 11-08-2009, 09:19 AM
Urathane is from grainger. search the word "devcon" <-Some messy stuff I must add..
And with the Kooks, they had to be removed to get to the engine mounts.
With the stock headers I hear its doable without removal.
Old 11-08-2009, 09:26 AM
lilgcts-v's Avatar
do you really need the puller tool to get the diff bushing out ?
Old 11-08-2009, 09:27 AM
I did it without, but the puller would of helped.
The rubber inside part of the sleeve poped right out . Then I made two very carefull cuts using a saw-zaw in the sleeve about 1/4 away from each other. ( you dont even have to go all the way through )
Then take a flat head screw driver and a hammer and tap the part you just cut.. Few light hits and it will fold right over .
Old 11-08-2009, 11:38 AM
SkullV's Avatar
It does look nice, but it is not necessary with Kooks headers. By moving the cats much farther downstream there is not nearly enough heat up there to melt the mounts. Lots of miles/auto-x/drag on mine with Kooks and no problems.
Old 11-08-2009, 01:30 PM
ya the guys at creative said with long tubes it doesnt get as hot and would be ok without a heat shield ...
But I still didnt like how close the mount was..
The header wrap was only 20$ at napa and it cant hurt.
Better to be safe then sorry
Old 11-08-2009, 02:17 PM
adanieljohnson1's Avatar
x2
Very nice bro! Man I cant wait until I get out of my rut so I can start the mod wars! lolz
Old 11-08-2009, 02:21 PM
tityrous's Avatar
nice job! you have a solid car sounds great too!
Old 11-09-2009, 08:08 AM
punishmentcycle's Avatar
is the uuc bushing a 2 peice?
Old 11-09-2009, 08:26 AM
SkullV's Avatar
I was looking at that too, it must be...I wonder if that allows any play/clunk over the Creative Steel Ultra Mount that Max is selling?
Old 11-09-2009, 08:36 AM
blk04V's Avatar
Your mounts are they "steel" or is that part of the name brand, "Creative steel motor mounts"?
Old 11-09-2009, 09:10 AM
SkullV's Avatar
Creative Steel is the name of the company. Ultra Mounts are the name of the mounts. They are Poly.
Old 11-09-2009, 12:30 PM
actually seems like a really good idea and looks tight...makes for a quick and easy swap if it should need replacement in the future.. i had to beat the hell outta mine to get the stocker out
Old 11-09-2009, 01:50 PM
SilveradoSS500's Avatar
Nice job
Old 11-09-2009, 03:47 PM
ya its 2 peice, but it fits tight, that thing isnt going anywere once its goes in ..
Quick Reply: My V finally Feels like a " SPORTS " sedan
