emissions tunning
Right now my cruising afr is pretty close to 14.7, should I be leaving it like that, or should I be leaning that out for the test? Also, how about the spark timing tables, should I load the stock one back in or should I be fine with added timing? anything else I should be looking at?
How aggressive is your cam? You still have the 3800 V6?
Easier thing... increase idle to 1100rpm. You can probably advance timing as well.
As far as Closed Loop AFR... you cannot adjust it with tuning... it will always hit around 14.7:1 due to O2 sensors.
Yes I still have the 3800 v6. My idle is set at 850 right now I believe. I am beginning to advance my timing and trying to smooth out the graph.
I dont know how aggressive you would consider my cam, the specs are -210/220 @ .050 -.320" lobe lift on the intake, .512 with a 1.6 rocker ratio-.320 lobe lift on the exhaust, .512 with a 1.6 rocker ratio -112 lobe separation.
The cat is still original.... I could force it to stay in open loop if that will help. As far as the closed loop afr, when I was calibrating the maf sensor early on I was getting an afr of around 16...I finally got the part throttle down to around 14.7ish, so I dunno....
1: does anyone know where to buy methal hydrate in Toronto? and how much do you add per litre of gas?
2: has anyone heard of shops checking the limit of your idle? I've heard that on one of the emissions stickers on the car there is an idle limit of 899 or something like that, and if you are above that idle they will automatically fail you?
2. Limit is 1250rpm. Automatic fail above that. I'd suggest setting it to 1100 for safety.
Mark
Mark
If you get the VE's in line with your O2 sensors, you will be running as close to stoich as possible. This is as clean as it gets and your cats will do the rest. To give you an idea, I passed in the middle of winter during a -20 cold snap with my thermostat recently replaced(1 month of broke thermostat in -30 temps not fun). No oil change, no special additives, no air filter change nada. I wasn't even close to failing.
Car is cammed, true dual exhaust over the axle, off the shelf magnaflow ODB2 cats, all bolt ons etc.
