Watch Out
Can you elaborate as to what happened?!
What happens now that they have your plates? Can you simply buy new ones? Or does your vehicle have to pass a drive clean test?
What modifications did you have?
What's the issue with your catch can? Is it that you have it installed where the EGR valve goes and you need a different physical spot to locate it?
Also, do your headers have the EGR hook-up with block-off plates?
1977 Chevy Camaro - in ontario classic cars are not required for Emission testing,
Motor 350 - over 50 ect.
No Cats, No EGR, Improper Oil/Air Filter Carcoal Canister. @ $365 each
they took my plates, and now im left standing without my ride, and as of right now no other car until next month.
The problem is that he has to drill a hole in that nice FAST!
SPD-KILZ -- I mounted my catch can on the other side of the engine because of the EGR valve --attached it to the RAD support in front of the ABS block. Looks like you have room for that and just need a bit more 3/8" hose.
Basicly the MTE/MTO are tageting nice cars, and ruining peoples days.i read above that someone had this happen and knew of something to get around this issuse. like i said i have no car, and i dont want to take transit. beside my work is 30km away, everyday. sooner the better!
Can you please post pictures of your catch can mounting location? Also, who makes your can?
I feel so bad for you! Who has possession of your car?
I don't have a camera handy but will try to get a shot on the weekend or at least tell you where I mounted the holder.
I've got the AMW Can shown here
http://www.accmachtech.com/catchcans.asp
