Canadian Members We never leave because we have The Beer Store
Car spuddering/missing
Old Jul 9, 2018 | 12:37 PM
Brandon_sebren's Avatar
Default Car spuddering/missing
I have a 2000 ls1 TA the car started missing out of nowhere I changed the plugs wires still had the problem hooked it up to my obd2 showed cylinder 6 so I changed the coil back well I’m still having the same problem when you first start the car over night it’s fine but get up the street a mile or so you can feel the gas pedal feel heavy as if it’s fighting my foot and not wanting to go throws a misfire 6 and sometimes random misfire code I have no clue what it could be any help would be appreciated
Old Jul 19, 2018 | 10:24 AM
transamtom's Avatar
Try swapping injectors with another cylinder,if that doesn't work then you need to do a compression test on that cylinder.
Old Jul 20, 2018 | 08:42 PM
cnd99hawk's Avatar
Let me know what you come up with.. I'm experiencing the same issue. I took the car out of storage late this year and I'm throwing a misfire code for cylinder 8.. it drives fine when moving.. pulls hard but when you stop I feel like I'm driving a cammed car lol
I'm going to change the plugs next week.. hopefully it doesn't go deeper than that.
good luck
Old Jul 21, 2018 | 07:40 PM
Redbull87's Avatar
Did you change the plugs and the wires or both? I rarely see oem ls coils go bad but if nothing changed from swapping them around then its probably not an issue.Injector as mentioned earlier could be at play.more often Ive had bad plugs..spider cracks on close inspection,also poor plug wire connection or arcing not being plugged in firmly. Other than using quality plugs/wires..having fresh fuel and everything else is upto snuff maintenance wise..your into a compression test leading into bigger problems.How many kms on that ls1?
