Canadian Members We never leave because we have The Beer Store
Slider pins
Old Jun 20, 2006 | 10:03 PM
Canuck's Avatar
Default Slider pins
I am doing a brake job on my 02 SS. I have a couple of slider pins that are stuck/seized and I cannot remove them in order to lubricate them. Any advice on how to remove them would be greatly appreciated. Also what do I lubricate them with?
Old Jun 21, 2006 | 08:48 PM
Hooper's Avatar
Use a bit of heat on them. What has happened is the rubber boot has been torn and allowed water into slider hole causing them to seize. Once the pin is out you can use sandpaper to remove the surface rust and grease them up. I was able to reuse my slider bolt. You should get some new boots though or they'll just seize again. You can get them from your local GM dealership.
