Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Front mount dist. question
Old Nov 8, 2010 | 03:41 PM
skidmarkSS's Avatar
Default Front mount dist. question
Where are you guys getting the block off plate that goes on top of the GM timing cover?it has 2 bolts holes and looks like the same shape as a fuel pump block off plate.it sits right next to the dist.on the right side.
Old Nov 8, 2010 | 06:46 PM
LS1MCSS's Avatar
If you use a mechanical fuel pump, I think, it has to be a ford, so look at ford fuel pump block off plates.
Old Nov 9, 2010 | 06:33 AM
ATwelveSec02Z28's Avatar
I got a $6 Ford Motorsports block off.... Flipped it upside down so you dont read "FORD MOTORSPORTS"
Old Nov 9, 2010 | 09:36 AM
speedtigger's Avatar
Old School Heavy
I was looking at that mechanical fuel pump location and I was thinking that if the fuel pump diaphragm sprung a leak, fuel would leak inside your motor. Seems like a small oversight unless I am missing something.
Old Nov 9, 2010 | 10:53 AM
skidmarkSS's Avatar
Good info,thanks,i am trying to get this thing wrapped up.
