Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
383 boosted setup input please
Old Dec 8, 2010 | 12:30 AM
1fastlsx's Avatar
Default 383 boosted setup input please
im building a 383 stroker with tc78mm turbo ****** carb vic jr intake 7lbs boost in a fbody i have a holly 96gph at 7psi will this feed with anough fuel thanks
Old Dec 8, 2010 | 06:59 AM
ZONES89RS's Avatar
In-Zane Moderator
96 GPH should FAIL. You need high pressure and output, something that can keep nailing fuel into the carb when in boost and a boost reference regulator that goes 1:1 with boost. The A1000 is the most common fuel pump you see on many street boosted rides.
Old Dec 8, 2010 | 09:46 PM
butler's Avatar
and a big fuel line
