Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
lq4 hp
Old Dec 16, 2010 | 11:46 AM
bigchief52780's Avatar
Default lq4 hp
does anybody know hp of stock lq4 with carb? what kind of increase will i get by swapping in a z06 cam with .525/.525 lift?
Old Dec 16, 2010 | 12:29 PM
ZONES89RS's Avatar
In-Zane Moderator
It will all depend on the intake, carb selection, headers and exhaust to determine the "possible" output from a stock 6.0.
What are the cam specs you speak of outside of lift? There are different LS6 grinds and i dont know if any with .525 lift besides a "hot cam" grind.
Old Dec 16, 2010 | 05:09 PM
duration 204/211 valve lift 0.525/.0525 lsa 116 this is from a 01 z06. i have the edelbrock dual plane intake with 750 holley dp and longtube headers
Old Dec 16, 2010 | 05:13 PM
ZONES89RS's Avatar
In-Zane Moderator
What size long tubes? what kind of holley? I will assume well over 400 foot pounds TQ with that setup.
Old Dec 16, 2010 | 07:30 PM
GoatPilot87's Avatar
I know Ive seen a lot hit the 500 mark with the 317 heads, and a decent cam with the Edelbrock manifold, and a good model 750 after being tuned. But then again the hp numbers I speak of were from one of the chevy magazines and I didnt pay attn to the power curve and I know a lot of magazine projects fudge on numbers to help the vendor of the parts theyre using for the article. I myself am planning on building a mild LQ9 with L92 heads so Id like to know some numbers also.
Old Dec 16, 2010 | 07:41 PM
i have 1 3/4 header mustang headers, bassani x pipe and 40 series flowmasters. Carb is a holley 4150. this is in a 89 foxbody with 3.73 gears and built th350.
Old Dec 16, 2010 | 08:06 PM
ZONES89RS's Avatar
In-Zane Moderator
Should be in the 400 range with HP and over 400 with torque.
