Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
acc. drive setup
Old Mar 18, 2011 | 05:54 PM
Joebob23's Avatar
Default acc. drive setup
was wonding if an ls1 alt. and ps brackets would fit on an lq4 because the truck ones look way out of place
Old Mar 18, 2011 | 06:43 PM
Prorac1's Avatar
IIRC there is a bolt hole on the iron block low on the drivers side that isnt drilled for the accy bracket. But you can physically bolt them on. The truck stuff sticks out further than the car stuff with the exception of the LS3, which is the same w/p and balancer as the truck stuff. Eric L
Old Mar 18, 2011 | 07:15 PM
NemeSS's Avatar
Sure but have to drill and tap iron block to use the fbod alternator and need to use fbody offset crank pulley. And wp.
There are other setups out there
Old Mar 18, 2011 | 07:19 PM
Joebob23's Avatar
yeah i dont want to drill and tap the block...what else can i get that is not sticking out like the truck acc.
