Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Coolant bleeder pipe
Old Mar 24, 2011 | 04:13 PM
L33_944's Avatar
Default Coolant bleeder pipe
What are you guys doing with your coolant bleeder pipe? Do you delete it or run it to the reservior?
Thanks,
Jeff
Old Mar 24, 2011 | 05:06 PM
ZONES89RS's Avatar
In-Zane Moderator
You have to run it to a pressurized source, i run mine to a T fitting in the heater hose.
Old Mar 24, 2011 | 05:20 PM
L33_944's Avatar
cool, sounds good.
Thanks
Old Mar 24, 2011 | 05:40 PM
GNCLONE's Avatar
How about this:
"GM's pink colored Dex Cool coolant has been used since the late 90s. It is sensitive to air pockets and has been known to congeal or turn gelatinous if the cooling system runs low on antifreeze/coolant. The LS1 designers knew these engines would be sensitive to air in the coolant system, so they devised a way to evacuate air from the block with the 1/4 inch steam ports or vents. There are four, two at the back of the block and two at the front. Because these engines are almost always installed at an angle, the rear two are often sealed or blocked, but the front two go to a high point in the cooling system, NOT to an unpressurized reservoir."
How 'bout dem apples!
Old Mar 24, 2011 | 06:10 PM
L33_944's Avatar
haha perfect! thanks guys
Old Mar 24, 2011 | 10:51 PM
pontiac 2+2's Avatar
Smile
You can also install a niple at the highest point on the water pump,and route the hoes there. works perfect and looks good!!
Old Mar 24, 2011 | 11:00 PM
h8tulooze's Avatar
Anyone have pics of theirs?
Old Mar 25, 2011 | 10:15 AM
rojs234's Avatar
Sure, here ya' go.
Old Mar 25, 2011 | 10:51 AM
stewdy1's Avatar
I just filled my motor up with water with the two fronts open then blocked them off
Old Mar 25, 2011 | 12:10 PM
h8tulooze's Avatar
Originally Posted by rojs234
Sure, here ya' go.
That's clean, thanks
Old Mar 25, 2011 | 09:18 PM
GC99TA's Avatar
I don't have a pic of mine right now, but the Champion aluminum radiator I installed in my 73 Camaro had two additional threaded bungs in the passenger side tank (no, not the trans cooler ports). Anyway, one was near the top very close to where the steam port line would attach to the radiator on an LS1 F-body set up. So I replaced the plug with a barbed hose fitting and routed the steam vent line to it. Looks like it was purpose built for this swap.
Old Mar 26, 2011 | 04:45 PM
GNCLONE's Avatar
Same here - the new radiator I got had an extra hole near the upper hose - looks like it is purposely made for steam ports. I hammererd a short little piece of brake line into some plastic and then epoxyed the piece into the hole.
My concern with the water pump fix is that the steam doesn't rise "down".
Old Mar 26, 2011 | 06:06 PM
ZONES89RS's Avatar
In-Zane Moderator
We do not permit post whoring here to raise post counts, just a FYI, not being a dick, just enforcing site rules.
Old Mar 26, 2011 | 06:24 PM
GNCLONE's Avatar
I wonder which LS vehicles used all four steam ports? So many have the rear two blocked off.
Old Mar 26, 2011 | 07:17 PM
Black&White's Avatar
The LS1 I'm using for my 70 swap used all 4. It was from a 99 Z28.
Old Mar 27, 2011 | 01:33 PM
irocguy's Avatar
My buddies got a 5.3 from what I don't know but it also uses all 4, I'm a bit curious to know to now...
Old Mar 27, 2011 | 10:19 PM
GC99TA's Avatar
Here's a pic of mine of mine that I mentioned above ^^^ You can see the brass barbed fitting I screwed into one of the extra ports in the tank.
Old Mar 28, 2011 | 11:33 AM
1970camaroRS's Avatar
Here was my solution.
And a very detailed post about it. Part came from Jags that Run.
https://ls1tech.com/forums/14148663-post97.html
Old Mar 29, 2011 | 10:26 AM
rojs234's Avatar
*1970camaroRS* has a good solution. I think both Jegs and Summit also sell a similar piece with different size NPT bungs. These also work well for an after market temp gauge sender. If you're handy ,you can easily make one yourself, as in "free" LOL.
Old Mar 30, 2011 | 11:12 AM
Paul57's Avatar
How about this:
Sounds to me like we should just quit using Dex.
They never had problems at this level in a traditional SBC.
