Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Demon float level...help!
Old Jun 2, 2011 | 08:11 PM
FormulaZR's Avatar
Default Demon float level...help!
Ok, so here's my question.
I know Demon has their problems, so this may just be a typical problem.
But, here's the deal. The front float cooperates fine; the rear float level won't lower. It's at the VERY top of the sight glass, but the adjuster nut is all the way in.
Ideas?
Old Jun 2, 2011 | 11:12 PM
3pedals's Avatar
I assume you are letting some fuel out of the rear bowl after each adjustment, and then letting the needle/seat determine the level as it re-fills?
If so then maybe that needle/seat is toast, look it over close.
Old Jun 3, 2011 | 11:04 AM
allblowdup's Avatar
Ideas?
If the nut is all the way in then the needle is all the out meaning high float level.
Old Jun 5, 2011 | 07:00 AM
Doug G's Avatar
Could be trash in the seat ?
As above, pull it apart...take a look...clean/replace as needed...flip the bowl upside down and pre-set it before re-installing...then you can set it closer once running.
Old Jun 5, 2011 | 11:11 AM
kevindglenn's Avatar
This would be my course of action...
