Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
50cc or not
Old Aug 7, 2011 | 09:19 PM
hifi875's Avatar
Default 50cc or not
Going from Vic mr to perf rpm intake on my 5.3 for more bottom end /midrange power. Do I go back to the 30cc access pump?
Old Aug 8, 2011 | 05:27 AM
Pop N Wood's Avatar
I would start there, yes. When it comes to accel pump and shot size always use the smallest shot needed to prevent a bog.
Old Aug 8, 2011 | 12:28 PM
xpndbl3's Avatar
i'd leave it on there and have someone watch behind you to see if you're leaving clouds of black smoke when stepping on it. Otherwise it may still need it, depends on converter and other things.
Old Aug 8, 2011 | 03:40 PM
ZONES89RS's Avatar
In-Zane Moderator
Wont know without trying it out.
Old Aug 8, 2011 | 04:21 PM
hifi875's Avatar
thxs fellas i'm gonna find out tonite(hopefully). Have to redo my steam lines because i had them run under my vicjr. and they wont fit under the perf rpm.
Old Aug 10, 2011 | 09:58 AM
hifi875's Avatar
got everything done. steam vents had to be plugged temporarily till i have some new hardline made. no off idle bog. thought the 50cc might be too big but as of now it seems fine. seems to have alot more bottom end torque. just need to reset the idle mixture with a vacumn gauge to get rid of some of the fuel smell. time to go to the track now.
Old Aug 10, 2011 | 01:13 PM
tennerv8's Avatar
I have the huge L92 heads. They need alot of fuel off idle since the intake runners are so big they give a week signal. The only thing that got rid of my off idle bog was a 50cc pump and a #40 squirter.
