Carb setup on ls1... Help
The original setup when I bought the block had the crossover with it tapped into the water pump. Now, do I need to run the crossover to the water pump or radiator? I will post some pics to specify what I am talking about.
Safe bet is to plumb them into a pressurized part of the cooling system. Raidator and waterpump are popular spots. Jaguars That Run sell a T with a vent and sight glass that plumbs into the upper radiator hose. Try a search
If you block them off, jack up the front end so the forward vents are the highest point then pull both of the plugs when filling the motor. Put the plugs back in once coolant starts coming out. You will need to do this every time you put a significant amount of coolant in. You should do both vents to get the air out of both heads.
Even with the vents hooked up I find pulling one of the vents is the quickest way to both fill and drain the coolant. They have O rings so they reseal pretty flawlessly.
my catch can....has oil in it now though
