Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Carb baseline setting help
Old Nov 26, 2011 | 01:06 PM
supspt454's Avatar
Default Carb baseline setting help
Hey guys, hope everybody had a great holiday? Ok so what I have is a 98 LS1 all stock, edelbrock GM A body headers, edelbrock vr jr intake, MSD 6ls, and a 750 cfm carb. Just to refresh people, this is in a 70 Chevelle with a Muncie 4 speed and 4.10:1 rear gear. Now, with that information out of the way, here is my carb specs...I bought the carb used as a QFT P 750, but I'm not quite sure. It has the QFT base plate, metering blocks, and bowls, but it has a Pro Form main body. I think it will be a good carb, but I'm uncertain of the baseline settings. Primary jets ate 73, secondary are 85, 65 power valve, 50 cc pumps with black cams, 31 squirters, and air bleeds are 73/36 on pri and sec. Does any of this sound like a good start point? Or do I need to make some changes? Thanks guys!
Old Dec 3, 2011 | 07:29 AM
supspt454's Avatar
Bump?
Old Dec 3, 2011 | 08:45 AM
JPH's Avatar
JPH
Yes that is a good starting point. I would say you would have to pull atleast 2/3 sizes of jet in the front and 3/4 in the rear if it is to rich for you.
