Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
HELP coil harness problems.
Old Dec 4, 2011 | 12:35 PM
supspt454's Avatar
Default HELP coil harness problems.
I have a problem with one of my coil harness. Here is the deal... I can start it up, let it run for 10 sec or so, shut it off, and the two cyl in the middle, either 3,5 or 2,4 header primaries stay cool while the others get hot quick. The engine has a miss and backfires. The reason I say 3,5 or 2,4 is because I swapped the harnesses and have the same results on either bank. I have checked continuity on all the wires in the harness, which has been cut and soldered back together, and all wires check good on the DVOM. WTF? I just don't understand why I can ring it out with the meter and it doesn't work on the car??? And it is almost impossible to find a replacement for thi early style ls1 harness. HELP!!!
Old Dec 4, 2011 | 05:12 PM
supspt454's Avatar
Oops, I meant 5,7 or 4,6 on the cyl.
Old Dec 20, 2011 | 04:06 PM
LS1MCSS's Avatar
Do you have the wires, that fire the coils, switched on those two cylinders, aka 5 and 7 need to be reversed?
