Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Help with engine choice.
Old Jan 17, 2012 | 03:23 PM
70acadian's Avatar
Default Help with engine choice.
So I need some info. I'm new to the forum, and i know if i searched long enough i would probably find the info-but you know how it goes until you find your way around. I'm looking at picking up a LQ9 out of a 07 truck. Its a steel block-alum head. Is there anything I should look out for aside from it being beat. I am going to carb it, stock heads except springs and bottom end-aside from arp bolts for now. Cam it, and all necessary changes to put in a 70 Nova. Basically I need to know if I am starting with a good choice of year LQ9. Any help greatly appreciated.
Old Jan 17, 2012 | 08:33 PM
ZONES89RS's Avatar
In-Zane Moderator
If you will be automatic trans, you are all go. The 99/2000 have cranks that cannot utilize a 6 speed, arp is cheap insurance, I spin my bone stocker with cam only to 7200, two years now, although not recommended.
Good luck and post a build thread to share with all if enthusiasts here!
Welcome to tech.
