Quick Ignition
I'll have to have a switch connected to the fuel pump as well right? and how do I wire up the 6010?
My car is completely stripped of wire and I haven't got my actual harness wired in yet.
If all you want to do is a 5 minute turn over then just jumper the power wire straight to the battery and a ground wire to the block/chassis.
As for the stock key it should be pretty basic to find a switched power wire with a wiring diagram. Most cars have have some type horn relay or main power relay the turns off when the key is off. Just wire it into that.
