Backfire Issue
This post is about a bad backfire issue and I dont want this thread being 5 pages long and we all end up talking about the tires I am using as being the problem...get where I am coming from? I have seen lots of threads take that direction and the original question not even being answered...thanks again guys..
GM 6.0 block .030 over to a 408 12.5:1
Callie dragon slayer crank,
Compstar rods, Ati super dampner,
Cam - .744/.766 .288/.306 115LSA Solid Roller
1/2 pushrods, jesel shaft mount rockers, Triple spring seat pressure 350 psi closed, 850 psi open, Trick flow custom 245 intake runner 255 cc exhaust runner, titanium vavles
Super vic intake, quick fuel 1050RQ series jetted appropriately for 12.8 AFR at WOT, front jets are 84 rear are 88. It came at 88, 96
Float levels are both right in the center.
Aeromotive A1000 pump with low press aeromotive return style regulator
MSD 6LS ignition controller box with MSD ignition coils......I have been running these coils for about 4 years now and I had it when it was EFI and had no problems even spraying up to a 350 shot on it. Plug reads were good.
ARE dry sump 4 stage oil system
MSD high torque starter
NGK br-7 non projected tip plugs for NA application gapped at .33-.35
I think that sums it all up
Edit: just noticed your cam likes that much idle timing. What was the temp out?
But IMO that is way too much timing at cranking speed. That could be contributing to the problem and is probably the reason why your starter was being overworked. Try setting it down to under 15 to 20 degrees at crank (500 RPM) then go ahead and ramp it back up at 1000-1500 RPM. That is the beauty of the MSD software.
With my car I find it better to not touch the throttle until after I am cranking it. If it doesn't catch right away then start pumping the gas.
