Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
valves
Old Oct 31, 2012 | 01:51 PM
jsanford's Avatar
Default valves
I have a set of 799 heads I'm taking to the machine shop to have milled. And I'm currently taking the heads apart and cleaning them. When I reassemble, should the valves go back into the SAME opening they were removed from? The heads are low mileage if that matters.
Old Oct 31, 2012 | 04:18 PM
Doug G's Avatar
Yes.
And I'd do a quick lap check....just to be safe.
Old Oct 31, 2012 | 05:13 PM
wildcamaro's Avatar
Yes put the valves into the matching guides due to fact they have worn as a pair...another trick you can use to test their sealing ability is turn the heads upside down and make sure the combustion chamber is level with whatever you set them on and fill them with alcohol or gas and see if any of the chambers leak down, if that's the case a quick lap or even a valve job is In order
