Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Looking for cam
Old Dec 5, 2012 | 04:09 AM
hatdude4's Avatar
Default Looking for cam
I have a 93 Mustang notchback with a LQ4, L92 heads(gonna get milled .030), 750 carb running e85, TH350, 4200 stall, and 4.56 gears. Looking for the best cam to get the most power. Was told when i bought the car that it has a procharged corvettes cam in it and want to swap it out for something that works better for this setup.
Old Dec 5, 2012 | 05:06 AM
ZONES89RS's Avatar
In-Zane Moderator
Call Geoff at EPS and get a custom spec grind. Will be worth it.
Old Dec 5, 2012 | 05:07 AM
ZONES89RS's Avatar
In-Zane Moderator
http://www.engpwrsys.com/
Old Dec 5, 2012 | 03:42 PM
hatdude4's Avatar
Thanks. Figured a custom cam would probably be best just didnt know or any companies that would be able to help with this setup.
Old Dec 5, 2012 | 07:05 PM
ZONES89RS's Avatar
In-Zane Moderator
Geoff will take care of you, just have allot of details on the setup and vehicle available.
Old Dec 8, 2012 | 04:38 PM
Prorac1's Avatar
Mike at Rapid Motorsports is another good LS3 cam source. Eric L
Old Dec 14, 2012 | 06:33 PM
hatdude4's Avatar
Anyone know if this XER281HR-12 cam would have any PTV clearance issues? Seen some others running this and having good results but no where does it say anything about PTV clearance. Found a new one for sale pretty cheap and looking for a cam to run until i build start my new motor build.
Old Dec 14, 2012 | 07:12 PM
windmill's Avatar
well what did it run,,,
Old Dec 14, 2012 | 07:25 PM
hatdude4's Avatar
What did what run?
Old Dec 19, 2012 | 04:10 PM
windmill's Avatar
i just figured u have it going by now,,,,
Old Dec 19, 2012 | 05:14 PM
hatdude4's Avatar
Last owner said it ran 6.69 in the eighth but I personally didn't get a chance to run it yet.
Old Dec 19, 2012 | 08:43 PM
speedtigger's Avatar
Old School Heavy
From what I have read, you can't put much cam in a square port head motor with milled heads. You may just commit to fly cutting as long as you are not planning to run nitrous.
