Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Cam Help
Old Feb 4, 2013 | 08:10 PM
ls1camaro00's Avatar
Default Cam Help
hey guys i just want to give thanks in advance for any help. with that being said, im building a budget 5.3 build. what i already have is the 5.3 with LS6 valve springs,edelbrock manifold, 750 carb, kooks longtubes 1 7/8, through a built 4L60E, and a 3200 stall. i dont have any cams in mind. not worried about driveability. just want to do a max effort budget build. thank you guys.
Old Feb 4, 2013 | 08:13 PM
by the way it will be a nitrous car. aiming for a 200 hit progressive.
Old Feb 5, 2013 | 01:56 AM
ZONES89RS's Avatar
In-Zane Moderator
The edelbrock 2215 cam will work great for you, but the 2216 would be better for power. Only issue I see is the converter may not be big enough or the 2216, but hell, give it a try and let us know. May work perfect. I think a 3500 would be minimum, but you are not far below that.
Old Feb 5, 2013 | 09:22 AM
TXsilverado's Avatar
i'd upgrade springs too.
Old Feb 5, 2013 | 12:51 PM
ZONES89RS's Avatar
In-Zane Moderator
The LS6 springs are perfect. I am however going to give edelbrock a call and see why they only want you to use a stock spring.
Old Mar 7, 2013 | 08:48 PM
Sorry guys I've been super busy with work doing about 16 hour days but I will let everyone know how everything goes. Thank you guys for all your help much appreciated.
