Help with a 5.3 carbed setup
What cams are recommended for a carbed 5.3 setup? Witch intake are you guys using? The Edelbrock performer RPM or the Victor JR? I will be using a 6010 box to run the coils and timing. What size carbs are you guys using on the 5.3 setups?
I don't have much time behind the wheel yet and it has not been down the 1/4. Still doing the interior. Good luck with yours.
How thin of a head gasket are you planning on trying to use? I think stock is .051 and pistons tend to be a little out of the hole. I am personally running .040 thick cometics.
The 200R4 is a question mark in the plan because they need to be modded to even handle 300+ hp. A good plan could put you at 425-450hp or even more.
The cam, intake, carb, stall, headers, gears and everything should be matched to your specific goal. Making one change can effect the other (good or bad) and could even make you do a 180'.
Regardless of your plan check with the poster above Mike F at S-K Speed before ordering anything, as he usually beats summit, jegs and a lot of times even the parts classifieds prices. Nothing but good things to say about him and their company.
^^^^ This exactly. Especially being a 5.3 there is very little out ther for carb stuff on them that will work well out of the box.
Spend the extra time and a few dollars and get a custom cam set-up for your application. You will be alot happier in the end.
We have had 2 shop cars that were LS carb swapped vehicles and theyboth performed considerabley better when we swapped in a carb specific cam.
