LY6 Carb engine HELP!
As for the lifters, there is no downside to replacing them except for cost. "LS7" lifter are the same as any new LS lifter. They all resolve to the same part number these days. They are all the same new design.
With 100k on the clock, the trunion bearing replacement is probably a good idea. I highly recommend using an arbor press to replace them as opposed to the vise method. It is just more stable and square. If you don't have one, they can be had from Northern Tool or such for about $80.
The thing about a used high mileage engine is that the more you get into freshening them up, the more they lose any cost advantage they had over purchasing a low mileage engine. Lifters, bearings, valve seals, rings, heads to the machine shop etc. Next thing you know you have spent way more on a high mileage engine then just buying a low mileage piece.
http://www.chevyhiperformance.com/te...p/viewall.html
Trunion upgrade is worth it for insurance. I have yet to puke needle bearings, but i cannot act like it is not a concern.
Fly cut the pistons, new springs, cam, pushrods and timing chains and let it eat.
Pat G is good as well, but he will only reccomend the grind and you will have to have someone grind it.
Martin is really going out of his was for us carbed guys, so just give him a shout.
If I have some takers willing to actually pay for the cam(at a reduced cost of course) I'd love to get the ball rolling on the square port SNS line-up.
Sorry for the hijack.
Now back to our regularly scheduled thread.
